If a specifier asks me to have a steel pipe galvanized in accordance to ASTM A53, what do I do?
First of all, we must distinguish the difference between ASTM A53 and ASTM A153. Most galvanizers are familiar with A153, Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware. However, we must be careful when we hear someone ask about A53 which is a completely different specification. In fact, ASTM titles A53 as Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded, and Seamless. Section 17 of ASTM A53, titled Galvanized Pipe, specifies requirements for galvanized pipe ordered under this specification. The section requires the pipe to be hot-dip galvanized with a grade of zinc conforming to Specification B6, Standard Specification for Zinc and gives requirements for weight per unit area of the coating.
ASTM A53 does not contain the requirements for the finish, appearance, or adherence of the galvanized coating that are present in ASTM A123, Standard Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Product. Also, the weight per unit area of the coating called for in ASTM A53 is exactly the same as the minimum coating thickness requirements of the same product in ASTM A123. Therefore, ASTM A123 is a more rigorous and thorough specification in regards to the galvanized coating. If a steel pipe is galvanized in accordance to ASTM A123, it will meet the requirements of section 17 of ASTM A53.
In short, if a customer asks for a steel pipe to be galvanized according to ASTM A53, you can tell them, We galvanize according to ASTM A123 which will meet the galvanizing requirements of ASTM A53.
Comments
john white
Our questions are 1) in regard to when steel pipe is produced and the finish product is sold as Galvanized Pipe ....does the production method of rolling galvanized coil into Galv pipe vs rolling hot black coil into pipe, then hot dipping it of same quality value for applications. 2) can pipe rolled with galv coil be produced as A53A or does it have to be labeled as another comp. spec such as A135A (due to A53A only being listed as HOt dipped process when finish product is Galv Pipe. Thanks for your advisement on these two questions. tks John
Add Your Comment
