My customer wants to know if the zinc I use meets EN 1179. What is this?
EN 1179 Zinc and Zinc alloys – Primary Zinc is a standard published by the European Committee for Standardization or CEN. The standard “…specifies the classification, chemical composition, marking and other requirements for primary zinc.” It has been adopted by other European standardization organizations such as British Standards (BSI). While North American galvanizers may be unfamiliar with this standard because of its infrequent use in the region, they will be familiar with ASTM B6 Standard Specification for Zinc. Both standards cover the requirements for zinc that may be used in the galvanizing process but do not cover secondary zinc produced through remelting. Each standard contains five grades of primary zinc (prime western, special high grade, etc.). Each grade has a corresponding color code that relates strongly to the two standards.
Once we know what is covered in EN 1179, the new question becomes: “If the zinc I use meets one of the classifications in ASTM B6, does it also meet EN 1179?” The two standards are nearly identical, however, there are a few subtle differences in chemical composition requirements between the two standards. The chart below shows which zinc grade in EN 1179 corresponds to which zinc grade in ASTM B6. It also summarizes the varying requirements of the two grades in the final column.
So does zinc that meets the requirements of one of these standards meet the corresponding grade of the other standard? The answer is: most likely. However, it will take a little bit of digging through both tables (shown below) and a look at the summarizing chart to deal with each case specifically.
Comparison of EN 1179 and ASTM B6
Color Code EN 1179 Classification ASTM B6 Classification Differences
White Z1 LME Grade None
Yellow Z2 Special High-Grade
ASTM B6 max Lead: 0.003%
EN 1179 max Lead: 0.005%
EN 1179 has no limit on Aluminum
Green Z3 High Grade
ASTM B6 max Cadmium: 0.01%
EN 1179 max Cadmium: 0.005%
Blue Z4 Intermediate Grade
EN 1179 has no limit on Copper
Black Z5 Prime Western Grade
ASTM B6 max Cadmium: 0.20%
Table 1 of ASTM B6- Chemical Requirements
  Composition %
Grade Color Code Lead Iron Max Cadmium Max Aluminum Max Copper Max Tin Max Total Non-Zinc Max Zinc, min by difference
LME Grade White 0.003 max 0.002 0.003 0.001 0.001 0.001 0.005 99.995
Special High Grade Yellow 0.003 max 0.003 0.003 0.002 0.002 0.001 0.01 99.990
High Grade Green 0.03 max 0.02 0.01 0.01 0.002 0.001 0.02 99.95
Intermediate Grade Blue 0.45 max 0.05 0.01 0.01 0.20 - 0.5 99.5
Prime Western Grade Black 0.05 - 1.4 0.05 0.01 0.01 0.10 - 1.5
98.5
Table 1 of EN 1179- Chemical Composition of Primary Zinc
Grade Classificcation Colour Code Composition in % (mass fraction)
Nominal Zinc Content 1 2 3 4 5 6
Total of Elements in Columns 1 to 6
max
max.
Cd
max
Fe
max
max
Cu
max
A1
max
Z1 White 99,995 0,003 0,003 0,002 0,001 0,001 0,001 0,005
Z2 Yellow 99,99 0,005 0,003 0,003 0,001 0,002 - 0,01
Z3 Green 99,95 0,03 0,005 0,02 0,001 0,002 - 0,05
Z4 Blue 99,5 0,45 0,005 0,05 - - - 0,5
Z5 Black 98,5 1,4 0,005 0,05 - - - 1,5
