ASTM’s copyright does not allow the AGA to include full-text versions of the listed specification online. However, the AGA does provide a compilation of specifications pertinent to galvanizing. Order a copy from the “Specifying HDG” section of the AGA Publications order form.
Specifications Relating to Hot-Dip Galvanizing
ASTM Standards – Hot-Dip Galvanizing
A 123/A 123 M
Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Products
A 143
Practice for Safeguarding Against Embrittlement of Hot-Dip Galvanized Structural Steel Products and Procedure for Detecting Embrittlement
A 153/A 153 M
Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware
A 384
Practice for Safeguarding Against Warpage and Distortion During Hot-Dip Galvanizing of Steel Assemblies
A 385
Practice for Providing High-Quality Zinc Coatings (Hot-Dip)
A 767/A 767 M
Specification for Zinc Coated (Galvanized) Steel Bars for Concrete Reinforcement
A 780
Practice for Repair of Damaged and Uncoated Areas of Hot-Dip Galvanized Coatings
B 6
D 6386
Practice for Preparation of Zinc (Hot-Dip Galvanized) Coated Iron and Steel Product and Hardware Surfaces for Painting
E 376
Practice for Measuring Coating Thickness by Magnetic-Field or Eddy-Current (Electromagnetic) Examination Methods
Canadian Standards Association (CSA) – Hot-Dip Galvanizing
G 164
Galvanizing of Irregularly Shaped Articles
International Standards Organization (ISO) – Hot-Dip Galvanizing
1461
Hot-Dip Galvanized Coatings on Fabricated Iron and Steel Articles – Specification and Test Methods
Related Specifications – Hot-Dip Galvanizing/Galvanizing Materials
ASTM
A 36
Specification for Structural Steel
A 500
Specification for Cold-Formed Welded and Seamless Carbon Steel Structural Tubing in Rounds and Shapes
A 501
Specification for Hot-Formed Welded and Seamless Carbon Steel Structural Tubing
A 563
Standard Specification for Carbon and Alloy Steel Nuts
A 572
Specification for High-Strength Low-Alloy Columbium-Vanadium Steels of Structural Quality
A 944
Standard Test Method for Comparing Bond Strength of Steel Reinforcing Bars to Concrete Using Beam-End Specimens
A 992
Specifications for Steel Structural Shapes for Use in Building Framing
B 201
Standard Practice for Testing Chromate Coatings on Zinc and Cadmium Surfaces
CSA
G 40.8
Structural Steel with Improved Resistance to Brittle Fracture
G 40.12
General Purpose Structural Steel
Superseded by G 40.20/G 40.21
General Requirements for Rolled or Welded Structural Quality Steel
Society for Protective Coatings (SSPC) & National Association of Corrosion Engineers (NACE)
SSPC SP2
Hand Tool Cleaning
SSPC SP5/NACE No. 1
White Metal Blast Cleaning
SSPC SP10/NACE No. 2
Near-White Blasting Cleaning
SSPC SP 11
Power Tool Cleaning to Bare Metal
American Association of State Highway and Transportation Officials (AASHTO)
T 65 (ASTM A 90)
Mass of Coating on Iron and Steel Articles with Zinc or Zinc-Alloy Coatings
M 111 (ASTM A 123)
M 232 (ASTM A 153)
