Search the KnowledgeBase
Hot-Dip Galvanized Steel in Water Applications
The varieties of water throughout the world differ to the extent that predicting corrosion rates is very difficult for all coatings. Many parameters affect corrosion of metals in a water environment , including pH level, oxygen content, water temperature, water climate and tide conditions, to name a few. Despite the difficulty of predicting corrosion, it is important to note that galvanized coatings on steel used in submersed applications is still one of the best methods of corrosion protection. It is common for hot-dip galvanized steel to perform flawlessly in harsh water environments such as seawater for eight to 12 years.
The first step in deciding whether galvanized steel is the right coating for your application is to determine what type of water will be used. Water can be divided into a number of different types; pure water (e.g., distilled water or de-ionized water), natural fresh water, potable water (treated drinking water), or seawater. Hard water and soft water also cause corrosion to different degrees, as do hot and cold water. The applications utilizing hot-dip galvanized steel range from boat docks and piers to pilings and dam trash gates.
See Also:
AGA Project Gallery (Select the Water and Marine Sector)
Galvanized Pipes and Potable Water
Submerged HDG Steel
The Performance of Hot-Dip Galvanized Steel Products
Comments
Add a Comment
Yes, notify me of follow-up comments
Please enter the word you see in the image below:
