Hot-dip galvanized steel has been used for more than 100 years in a myriad of projects across the world. Specified not only for its superior corrosion protection and durability, but also for its low maintenance, economial benefits, low environmental impact, and even asthetics.
In this section, you will find the HDG Case Studies database which features galvanized steel projects around the world. The often stunning photos accompanied with descriptions of the project and reasons for galvanizing will inspire you to design your own galvanized steel project. The projects are sorted according to environment, sector, location, and reasons for galvanizing to ensure you can quickly find the type of project you desire.
Also in this section, you will find information on our annual awards program, Excellence in Hot-Dip Galvanizing Awards:. Many of the projects in the Case Studies database are past award winners or submissions. In the Excellence Awards section, you can view past winners, and submit your projects.
Finally, you will find some general information on the sustainability of zinc and hot-dip galvanized steel. Check back soon for updated environmental information.
